multiple exits
Old   June 2, 2015, 04:40
Post multiple exits
Piyush Aras
piyusharas is on a distinguished road
I am working on project that involves simulation on vertical plate falling film tower.
It is a chemical equipment used for heat transfer.
Design of it is very simple. There is a inlet at center top from where water comes in and gets collected in a tank .There are 8 slit openings in tank
I just want to know how much water will flow out from each opening.
I have designed a model , I have done meshing and created named selections of inlet ,walls and 8 outlets.
I am confused in the setup of boundary conditions and rest solution intialization things in fluent.
PS : I know the inlet flow rate but don't kniow anything else.
piyusharas is offline   Reply With Quote
falling film tower, multiple exit, setup fluent
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[ICEM] Multiple edges asal ANSYS Meshing & Geometry 2 March 22, 2013 10:10
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Flow region with multiple exits Dimitris CFX 4 December 1, 2008 08:49
Multiple reference frames? Moon Siemens 0 March 4, 2003 06:32
