Finding the stall angle of an airfoil through rotating transient
Old   December 5, 2015, 03:16
Default Finding the stall angle of an airfoil through rotating transient
Aman uz zaman Baig
aman_baig is on a distinguished road
How can I check the stall angle of an airfoil? I have read something that in transient mode we can rotate the airfoil and check where it stalls, but how can we do this? An elaboration would be very appreciated.
aman_baig is offline   Reply With Quote
Old   December 6, 2015, 15:29
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
  • What you are stressing on is a Dynamic Meshing Mode which you can achieve through a UDF (User Defined Function).
    Stall happens at a certain angle of attack when the Lift force suddenly drops.
    You don't need a moving mesh ( which you are going for) to find out the stall angle.
    Just use normal transient mode and change the angle of attack until the CL drops suddenly, if you are only interested to find out the stall angle.
shereez234 is offline   Reply With Quote
Old   December 7, 2015, 07:57
Aman uz zaman Baig
Thank you for your response. How can I change the angle of attack in transient mode during simulation? I am not much acquainted with transient simulations.
Old   December 7, 2015, 08:53
shereez234's Avatar
M Sereez
You can manually Enter X and Y component of Velocity in the boundary condition i.e. if Angle of Attack = 0 then X component of Vel = 1 and Y component of Vel = 0 m/s. ( Using cosine relations - google it).
airfoil, stall angle, transient
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 16:18
Pitching Airfoil angle of attack albinjohny OpenFOAM Running, Solving & CFD 11 November 16, 2018 05:31
Lift Coefficient vs Angle of Attach for Pitching Airfoil fkanyako FLUENT 3 July 16, 2014 07:35
Finding angle from line1 to line2 in ccw sense(2d) zonexo Main CFD Forum 2 September 9, 2005 06:40
Rotating Stall in Centrifugal Compressors Paul den Held Main CFD Forum 3 October 11, 2000 02:50
