fluent buoyancy flow
Old   April 12, 2017, 04:42
Default fluent buoyancy flow
zhouyu
zhouyu is on a distinguished road
hello
I'm trying to simulate turbulent mixed convection in a enclosure.
the buoyancy force due to temperature is considered.
the boussinesq approximation was used.
the turbulent model was rng ke. the enhanced wall treatment was applied.
I had tried two ways to get a better solution:
1. first, set the gravitational acceleration as a small value(0.098), and solve the case with first-order. then change the gravitational acceleration to 9.8. finally, solve the case with higher-order scheme.
2. first, solve the velocity field without temperature, and after it convergence, solving the energy equation with the momentum equations together.
but it was hardly to get the convergence solution.
can anyone give me some advises?
thanks very much!
zhouyu is offline   Reply With Quote
Old   February 11, 2018, 17:46
Yuehan
wc34071209 is on a distinguished road
I am having the same problem. I tried both the ways you mentioned but I still cannot obtain converged solution. Did you eventually solve the problem?
Originally Posted by zhouyu View Post
hello
thanks very much!
wc34071209 is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Fluent v15 multiphase flow b.c. failure Non-channel flow mickjazz Fluent Multiphase 1 September 22, 2014 06:41
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
Supersonic flow over an airfoil. FLUENT Lift don't match up with Shock Expansion Tech enriccasas FLUENT 1 August 21, 2013 06:43
Different flow patterns in CFX and Fluent avi@lpsc CFX 6 April 17, 2012 01:22
