Udf for heat source
Old   May 23, 2002, 10:40
Default Udf for heat source
Thomas
A porous medium is included in a domain. I want to define a heat source to the porous medium which will be a function of the temperature difference between the porous temperature and the domain temperature. Thanks for any help, Thomas
Old   May 23, 2002, 21:08
Default Re: Udf for heat source
Keil
It's possible. The DEFINE_SOURCE macro is available for your problem.
Keil
Old   May 23, 2002, 22:52
Greg Perkins
If you're using the standard porous media model in Fluent 5 or 6 you won't be able to model interphase heat transfer or have a model that assumes non-equilibrium between the two phases. Fluent assumes, a single energy equation for solid and fluid as described in the manual.
To model a porous media without thermal equilibirum you need to use udfs/udss...
I have presented some code for this in 2000 and 2001. Its also in the udf repository....search the archives for the posts/code.
Greg
Old   May 30, 2002, 04:12
Laika
Interesting,
where to find this udf repository?
thanks in advance,
Laika, still orbiting
Old   May 30, 2002, 04:36
Greg Perkins
Repository at
ftp://ftp.cfd-online.com/fluent
and my code at
ftp://ftp.cfd-online.com/fluent/udf_scalar_dos.c
Greg
Old   June 1, 2014, 02:27
M.H.Sajid is on a distinguished road
Dear Greg Perkin,
This is to let you know that I am working with heat transfer in porous media and have found your replies on this site very helpful. I wanted to download "udf_scalar_dos.c" but unable to download. I am using my user name and password of this site to download but it showing unable to login. Please let me know how to download it, or if possible,please email the file to me.
Thanking you
Sajid
M.H.Sajid is offline   Reply With Quote
Old   June 9, 2015, 10:55
Default (define_source) heat generation changs with location
何杰
zhebenshu1912 is on a distinguished road
hello everyone!
I write a udf for heat generation with different location(xyz),but only a part of fluid has heat generation.
project:a solid (0.08X0.08X0.1 to xyz) with 2 cylinder(r=0.01),cylinder is fluid with heat generation.
the code:#include "udf.h"
DEFINE_SOURCE(heat_flux, cell, t, dS, eqn)
real a, b, c;
real x[2] = { 0.02, -0.02 }, y[2] = { 0,0 }; //x、y source location
real p[8] = { 0.025, 500000000, 0.025, 500000000, 0.075, 500000000, 0.075, 500000000 };//0.025、0.075 is Z location,source value follows.
real pos[ND_ND];
real source=0;
int i, j = 0;
C_CENTROID(pos, cell, t);
a = pos[0]; //abc acquire xyz
b = pos[1];
c = pos[2];
if ((c >= p[0] - 0.025) && (c <= p[0] + 0.025)) //judge Z location
i=0;
while(i<2){
if ((a <= x[i] + 0.01 && a >= x[i] - 0.01) && (b <= y[i] + 0.01 && b >= y[i] - 0.01)) //judge xy,if meeting the range,give source right value
{source = p[0 + i+1];
dS[eqn] = 0;
i=2;}
i=i+1;
else
if ((c >= p[4] - 0.025) && (c <= p[4] + 0.025))
i=0;
while(i<2){
{source = p[4+2*i+1];
dS[eqn] = 0;
i=2;}
i=i+1;
else
{ source=0;
dS[eqn]=0;
return source;
the result shows the right cylinder has heat generation ,but the other one has zero.
thanks for your kindness.contact me:956400837@qq.com
zhebenshu1912 is offline   Reply With Quote
Old   June 9, 2015, 11:00
何杰
hello everyone!
real a, b, c;
real pos[ND_ND];
real source=0;
int i, j = 0;
b = pos[1];
c = pos[2];
i=0;
while(i<2){
dS[eqn] = 0;
i=2;}
i=i+1;
else
i=0;
while(i<2){
dS[eqn] = 0;
i=2;}
i=i+1;
else
{ source=0;
dS[eqn]=0;
return source;
UDF for energy source João Fernandes FLUENT 4 October 17, 2008 04:53
UDF - source terms Fred FLUENT 2 October 11, 2005 20:53
help on UDF mass source shao1 FLUENT 2 July 11, 2002 20:36
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
