Variable against theta (degree) from 3D cylinder
Old   June 23, 2015, 12:58
Default Variable against theta (degree) from 3D cylinder
Ontario
CCHunter is on a distinguished road
I am trying to get the results of heat transfer vs. theta for a specific section of a 3D cylinder using Fluent. I've attached two pictures, the first one is of the cylinder itself and the 2nd one is with a plane intersecting where I want to see the results of heat transfer vs. theta around the cylinder surface.
Thanks.
CCHunter is offline   Reply With Quote
3 dimensional simulation, cylinder domain, fluent 13, theta component
How to plot Cp vs. Theta on a 3d Cylinder nsiderbam FLUENT 10 March 4, 2019 14:55
flow around a circular cylinder with velocity inlet and outflow outlet shuoxue OpenFOAM 1 March 3, 2014 10:42
plot (local nusslet number/modified rayleigh) v/s theta around a cylinder in fluent me_geo Fluent UDF and Scheme Programming 0 September 18, 2013 02:43
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
