July 6, 2015, 14:10 |
Mass loss of a closed system in Fluent
Yu Han
Hi guys
I am currently simulating an boiling situation of the a tank (regardless what kind of 2D shape is). It is a closed system and B.C. are all set as constant heat flux from all four sides. whatever multiphase type I chose, the system is actually losing mass significantly. Even the system only contains gas, the mass is still not conserved. The gas is set as ideal gas. |
fluent |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
How can I track the progress of FLUENT when running ANSYS System Coupling | yhy20081016 | FLUENT | 1 | June 4, 2013 12:03 |
Checking mass loss | sachinthakre | FLUENT | 0 | February 6, 2013 05:44 |
Split boundary zone in FLUENT for mass flow | eishinsnsayshin | FLUENT | 1 | January 18, 2013 13:43 |
