Problem in recording picture
Old   July 7, 2015, 05:23
Default Problem in recording picture
BharathGM
For_Cfd is on a distinguished road
Hi all,
I am running a transient case and in first window the residuals are running with time steps and the time is updating every mili seconds which is displayed under residual graphs. And in the second window i am trying to record the movements and save pictures at every 20 time steps.
But in the second window the time is not at all moving and it is stuck as [Mesh (Time=0.0000e+00)] and therefore the pictures saved at every 20 time steps till 2500 time steps are showing initial picture only without movement i.e., at 0-second..
Can anybody tell me why it is happening like this..
Thanks a lot in advance..
For_Cfd
For_Cfd is offline   Reply With Quote
Old   July 7, 2015, 05:55
BharathGM
If i stop the running at middle and go to boundary conditions and if i select and deselect the HIGHLIGHT ZONE option then the time step in the second window will get update at that point of time with the fluid movement. And if i start the run from the middle again the time step will not get update nor the fluid movement, no matter how many time steps you make it run..
I think the problem is i might missed some option in the middle, could any one tell me where might the problem be going. if anybody come across this.
Thanks a ton in advance..
For_Cfd.
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
