July 7, 2015, 15:55 |
DPM coal combustion setting problem
Linwei
Rep Power: 11 |
I want to use DPM model to conduct the simulation of coal combustion and now I met two problems.
1) material properties of coal_hv According to proximate analysis, there are Moisture, Volatile, Fixed Carbon and Ash. I chose "coal_hv" as material under Combusting--Injection--DPM, but I found I could define "Volatile Component Fraction" and "Combustible Fraction" of "coal_hv" under "Materials". So do I need to define the fraction of Moisture and Ash? If so, how can I do? 2) chemical reactions For the chemical reactions related to coal combustion (e.g. C + O2 = CO2 & C + 0.5O2 = CO & C + CO2 = 2CO & C + H2O = CO + H2), I want to define the reaction rate by my own udf code. But I couldn't find where to define these chemical reactions and then choose the reaction rate. P.S. I didn't enable Multipahse Model, so I couldn't define reactions through "Reactions--Phases". Thank you very much. |
July 9, 2015, 01:46 |
widi
Rep Power: 11 |
are you simulate combustion coal from exhaust stack?
dpm coal setting |
Combustion with DPM | NiBa | FLUENT | 0 | February 18, 2015 08:23 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
combustion problem | mcnair | CFX | 9 | March 22, 2011 14:06 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
Coal combustion with Fluent 4.5 or 5.0! | Sriram Popuri | Main CFD Forum | 2 | July 24, 1999 11:34 |
