Multiphase mixture Cavitation model for bearings
Old   July 14, 2015, 05:15
Default Multiphase mixture Cavitation model for bearings
Vedant
vedant123 is on a distinguished road
Hi friends! I am simulating journal bearings in which i am using mixture model of multiphase flow. In that i have doubts in Cavitation model, which i am using, as in attached fig.In this model, what is the vaporization pressure and condensation factor? Is it constant value for particular fluid ? Where i will get these properties?I am using SAE40 oil. So what will these values for SAE 40 oil? If these values are not available then what are the default values i can take in order to get converged solution?
Plz help guys. Thanks in advance.
vedant123 is offline   Reply With Quote
A question about UDF utility in mixture and multiphase model aleisia Fluent UDF and Scheme Programming 0 June 7, 2011 16:32
MULTIPHASE - FREE SURFACE & MIXTURE MODEL Aris FLUENT 3 April 28, 2009 11:46
air and water vapour mixture - multiphase model Saba FLUENT 0 February 10, 2009 12:05
UDF for the mixture model khar nab FLUENT 0 July 31, 2008 06:29
Mixture Model (cavitation) Victor FLUENT 3 April 5, 2005 04:38
