August 10, 2015, 05:49 |
Operating Pressure and Outlet Pressure
Gustavo
Rep Power: 10 |
If I would like to work with 1 Pa pressure. So I Need to set Operating Pressure as 1 Pa and pressure outlet 0 Pa? It will Change if the pressure outlet of the Domain changes? For example, how would it be in the following 2 cases? 1) pressure outlet of the Domain = 1Pa 2) pressure outlet of the Domain = 101325 Pa thanks |
August 10, 2015, 08:23 |
Lucky
Rep Power: 66 |
The default operating pressure is 101325 Pa. Pressures are specified in gage pressures so if you set the operating pressure as 1 Pa and:
1) pressure outlet = 1 Pa the outlet would be at an absolute pressure of 1 + 1 = 2 Pa 2) pressure outlet = 101325 Pa the outlet would be at an absolute pressure of 1 + 101325 = 101326 Pa |
August 10, 2015, 10:36 |
Gustavo
Rep Power: 10 |
Thank you for your answer.
So based on what you have said, if I set the Operating Pressure as 1Pa, and outlet pressure as 0Pa, then the absolute Presurre in the Outlet will be --> 1 + 0 = 1Pa, correct? So I set right because I would like to work with low pressure, correct? |
August 10, 2015, 12:05 |
Lucky
Rep Power: 66 |
Yup.
Good luck. |
Pressure Driven Supersonic Flow in Converging-Diverging Nozzle | cdm | OpenFOAM Running, Solving & CFD | 7 | August 28, 2019 01:37 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
