Spinning Projectile
Old   August 19, 2015, 04:03
Default Spinning Projectile
Muhammad Imran Attari
2626imran is on a distinguished road
Hi. I have to predict the aerodynamic coefficients of a spinning projectile. I am using Fluent 15 solver. I generated the mesh of 1.4 million elements. I am performing the steady simulations using double precision, density based, explicit solver. The viscous model is Transition 4 Equation SST. I have to perform the simulations between 0.6 to 2.5 Mach number at different angles of attack. My problem is that the solution does not converge for lower Mach numbers even after 4000 iterations. Can any one please help me?
2626imran is offline   Reply With Quote
Projectile Moving Inside a Barrel amin.z FLUENT 0 February 24, 2015 00:26
how to create one DEM particle (projectile) raguelmoon STAR-CCM+ 4 January 12, 2014 08:32
Strategy for a projectile moving inside a tube kiwa21 Main CFD Forum 0 March 7, 2013 14:49
ICEM: Projectile Meshing and Modelling Issues gman89 ANSYS 0 May 11, 2011 23:01
emptying liquid from spinning circular tube uvce Main CFD Forum 0 July 2, 1999 10:26
