Benchamark study of CAARC building
Old   August 18, 2015, 08:18
Default Benchamark study of CAARC building
Paulina
p_kmb is on a distinguished road
Hi all,
I'm trying to recreate cfd study described in this paper of Huang and Li http://www.sciencedirect.com/science...43974X06001593
I've couple problems.
As it is shown in the article there should be some oscillations of Cd and CL for LK and MMK RANS model, which I cannot obtain (maybe mesh problem). I tried LES, and got nice oscillations and vortex shedding.
So starting from my last struggle:
For LES there is pretty good agreement of the Cd and Cl, but the pressure coefficient on the front wall is around 0.3. In the reference tab for pressure value I used 0. Should it be something else?
The boundary conditions:
velocity inlet
outflow
wall slip condition for roof and side walls walls of the domain
for RANS:
k-e standard or Kato Launder
enhanced wall function
It is said to use PISO for transient simulations but I got an error: floating point exception. The values of Cd and CL for RANS simulations are ok. The problem is that they don't oscillate, the flow is steady although it shouldn't be with the sharp corners and Re=1e5.
I count on your help.
Paulina
p_kmb is offline   Reply With Quote
Old   August 24, 2015, 10:41
Paulina
I red some other threads about pressure and pressure coefficient.
In my incompressible flow case, I've velocity inlet and outflow.
The operating condition and reference pressure location are fluent default 1 atm and (0,0,0).
The (0,0,0) point is in the middle of my model. Moving the ref point location to the inlet plane (-1.1585,0,0) changes max Cp value at the front wall of the building to 0.89. And I leave the pressure in the reference value tab equal to 0.
Am I right to change the location? If yes, what is the right location for reference pressure? Should I change also the z coordinate?
building, external flow
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 14:56
Grid dependency study in building heat transfer sunilpatil CFX 4 April 11, 2013 09:26
CP on CAARC building rcumming7 Main CFD Forum 0 February 15, 2013 12:19
Paraview Compiling Error (OpenFOAM 2.1.x + openSUSE 12.2) sfigato OpenFOAM Installation 22 January 31, 2013 10:16
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
