Error: Divergence detected in AMG solver: epsilon |
December 19, 2017, 14:37 |
William Foltz
Rep Power: 8 |
I am simulating sea water flowing through a perforated plate. I am using the VOF model, and the Reynolds Stress model (default options). I keep getting results that look like what's shown in the picture, and the error message is "Error: Divergence detected in AMG solver: epsilon". I've poured through many forum posts and fluent manuals, and I still can't figure out why this is happening. Thank you in advance! (Blue is air, red is water) |
December 20, 2017, 02:06 |
Paritosh Vasava
Rep Power: 22 |
Could you check where is this error occurring? Have you put any operating density, if not try that and see how it goes.
December 20, 2017, 15:42 |
William Foltz
Rep Power: 8 |
I'm not sure what you mean by check where the error is occurring. I have the operating density set to that of air. I've already simulated the same case using the k-epsilon model, and I tried to use the same inputs to run the RSM case. Is this a bad idea? I've been trying to find resources that will help me set up the simulation using RSM, but still no luck .
Two Phase Flow In Vertical Pipe | stonepreston | FLUENT | 2 | October 31, 2017 08:35 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
Divergence detected in AMG solver: pressure correction | aja1345 | FLUENT | 3 | September 1, 2015 23:58 |
Divergence detected in AMG solver: pressure coupled | n.jithin.1991 | FLUENT | 6 | January 5, 2014 11:43 |
Error: Divergence detected in AMG solver: x-momentum/ epsilon/ temperature | bubuchacha | FLUENT | 6 | February 26, 2013 03:30 |
