Donut Sectioned Pipe Flow
Old   October 23, 2016, 15:25
Default Donut Sectioned Pipe Flow
cptfreak3 is on a distinguished road
I am trying to reproduce an example of a laminar flow through a pipe. Like this:
So I am trying to make a 2D analysis by drawing a rectangle and then use axial symmetry. The problem is that if I select the axis of the pipe as the axial symmetry axis, the Jacobian of the Navier-Stokes equation is gonna tend to infinite and I'm going to have bad results around this area. So the suggestion is that I take a small region around the axis out of the problem, by imagining the section of the pipe is a donut. Like this:
My problem is that I don't know how to make this geometry with axial symmetry.
When I select the axial symmetry axis, it can't be a line am I right? There has to be some kind of of body, and I only have one body which is a surface, and the axis is out of it. This axis is represented in blue here:
Also, what kind of boundary should I select for the "wall" with the green question marks over it? It can't be a wall, because I want a velocity profile like this:
Thank you all in advance,
Luís
cptfreak3 is offline   Reply With Quote
Pipe flow with obstacle - HELP Min FLUENT 6 January 31, 2017 14:28
Setting boundary conditions for simple pipe flow with flow direction changing in time Sipher FLUENT 1 May 4, 2015 20:05
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 11, 2012 23:18
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 20:41
Pipe Flow Saima CFX 1 January 10, 2011 16:41
