September 9, 2015, 20:49 |
Calculation time - solving time
Dobromił Pszenny
Rep Power: 10 |
is it possible to check solving time in Fluent? I mean time beetwen clicking "calculate" button and "calculation complete" statement. Without using barbarian-style method like stopwatch, of course |
September 10, 2015, 13:38 |
Lucky
Rep Power: 66 |
I don't know how to do it in serial mode but in parallel mode from the GUI you can click on Parallel>Timer>Usage and it will print the wall time and cpu time. In TUI you just use /parallel/timer/usage
September 10, 2015, 14:47 |
#3 | |
Dobromił Pszenny
Rep Power: 10 |
Thanks Lucky,
i don't know much about using parallel mode - how does it affect my simulation? I am using Fluent to simple transient simulation and in serial mode after ~10 iterations solution is converged but in parallel mode Fluent is not stopping calculation even after 200 iterations... I am running it in 1 process - how much should I use? Quote:
EDIT: I have tried command "solver-cpu-time" also, but Fluent is returning "invalid command". |
September 10, 2015, 15:19 |
Lucky
Rep Power: 66 |
Total wall clock time should be what you are looking for.
There's almost no difference between serial or parallel if you are only running on 1 process, so I have no clue why you solution doesn't converge when running in parallel mode. Algorithmically there is no difference, except that the communication between the head node and compute node is now done via mpi rather than direct communication. Mesh partitioning occurs if you run on more than 1 processes (by default it generates one partition per process). The partitioning causes some differences in discretization at the partition boundary, but the effect should be minor. |
October 23, 2016, 08:30 |
Don't forget ()
milad
The right format of this command is " (solver-cpu-time) ", you must type ().
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
