July 2, 2013, 04:03 |
how to implement a Real gas law in fluent?
Rep Power: 14 |
Hi.
I’m simulating two-phase flow with combustion inside a closed volume. In fluent the density of the compressible gas phase is calculated by using “ideal gas law”. I want to use ‘’real gas law’’, for example Nobel-Abel law. But I don’t know how to implement this new law into fluent via UDF. Regards,
Does anyone have an idea how I can do this? </SPAN> |
July 2, 2013, 07:30 |
Yash Ganatra
Rep Power: 13 |
Go to Materials, then from Density tab select Real Gas but i don't think Nobel Abel Law is there. There are other options.
If you want to stick to Nobel Abel Law, then you will have to write a user defined function. (UDF) Yash |
July 4, 2013, 02:24 |
Rep Power: 14 |
Hi Yash,
thanks for your reply. Yes I want to use Nobel-Abel Law, and I can easily write an UDF for that. But the problem is in fluent if we use a Nobel-Abel Law instead of Ideal gas law, we should change a few other parameters such as the sound speed, the entropy and some Derivatives such as the partial derivative of density with respect to pressure at constant temperature. So the density law and the sound speed will be incorporated through the material panel. But for the others parameters I didn't find a way to incorporate them into fluent!!!! Regards, |
July 4, 2013, 03:14 |
Yash Ganatra
Rep Power: 13 |
Just go through Define Property Macro in FLUENT UDF and see if such changes can be incorporated through UDF
July 4, 2013, 03:16 |
Yash Ganatra
Rep Power: 13 |
See DEFINE PROPERTY macro in UDF and check if such changes can be incorporated via a UDF. Could you kindly tell which problem are you working on?
Yash |
November 13, 2015, 17:28 |
navid
Rep Power: 16 |
Hi NAD,
Were you able to solve your problem? If so could you please tell me how did you implemented the real gas udf in Fluent? |
compressiblity, ideal gas law, two-phase flow, udf |
NOx UDF | Abhishek Asthana | FLUENT | 5 | October 12, 2016 07:24 |
view factor | yoollooz | Fluent UDF and Scheme Programming | 0 | March 1, 2013 00:44 |
UDF for Turbulent Viscosity | Lourival | Fluent UDF and Scheme Programming | 3 | October 13, 2012 03:09 |
0 or 0.0 in udf | wlt_1985 | FLUENT | 5 | June 29, 2011 16:27 |
Real Gas Mixture With Reactions | Jake Cannon | Main CFD Forum | 0 | January 16, 2007 11:46 |
