Rotation Velocity in MRF for a Rotor
Old   September 16, 2015, 09:37
Default Rotation Velocity in MRF for a Rotor
Ali
Hybrid is on a distinguished road
I am simulating a helicopter rotor in Hovering, it's two bladed heli. I setup only one blade with periodic boundary condition and used MRF in Ansys Fluent.
The confusion is about the Rotating Speed input to the Moving Cell Zone. In my case, rotor should rotate Clock-Wise Direction looking from top.
I simulated two situations where once I input a "Positive Rotation Speed i.e. CCW" and in second case I put "Negative Rotation Speed".
Which one is correct? as my case is new, no data is available to compare the results. I attached Velocity vectors in Moving Zone and in Stationary Frame.
The solution is not fully converged in one case so just check the orientation.
One more thing, How can I give Pitch Angle to blade?
Kindly comment and suggest?
Best Regards
Ali
Hybrid is offline   Reply With Quote
Old   September 16, 2015, 17:11
jsm
JSM
jsm is on a distinguished road
From your contour image, I assume that Y axis is rotational axis and you need to rotate the blades in CW.
Then you need to define (0,0,0) as origin & (0,-1,0) for axis direction and corresponding rotational speed. Negative rotational speed is not recommended. But Fluent can solve it.
I can not understand the question about pitch angle. Why you need to input in Fluent? If your mesh is periodic, then Fluent will take the pitch angle automatically.
With regards,
JSM
jsm is offline   Reply With Quote
Old   September 16, 2015, 21:34
Ali
From my contours, which case presents real flow physics (i.e. in reality, blades will move Clockwise)?
I am still confused. I am posting some more pictures of my simulation setup.
Best Regards
Ali
Old   September 16, 2015, 22:03
jsm
JSM
Your case set up is not correct. For rotor zone, you set Translation motion. It should be rotational motion. Also why are you enabling "Frame motion" for stationary zone.
Please refer some Fluent tutorials in turbo machinery to understand better.
With regards,
JSM
Old   September 17, 2015, 00:16
Ali
That is mistake to put translation in Rotor.
Frame motion is enabled in stationary zone (Speed = 0rpm) to make zones periodic (Conformal).
Best Regards
Ali
Old   September 17, 2015, 09:20
jsm
JSM
No need to enable frame motion to make periodic. You can define axis origin and direction without enabling that.
That's the reason, I am recommending to refer some fluent tutorials in turbo machinery.
With regards,
JSM
blade, helicopter rotor, multiple reference frames
AMI Motions: Ramped Rotation Speeds and Nested Sliding Interfaces lordvon OpenFOAM Programming & Development 0 September 24, 2013 01:30
Rotation in MRF Feitan FLUENT 3 June 20, 2012 13:41
UDF to change Rotation Speed in a MRF simulation Mike FLUENT 3 September 27, 2011 06:46
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 08:42
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
