Fluent Capability for solving Polyhedral Mesh |
September 16, 2015, 11:43 |
JSM
Rep Power: 20 |
Hello All,
I found an beta feature for polyhedral mesh generation in fluent-meshing 16.2 version. It looks like, we can get good quality than tetra mesh for complex geometries. My question is, Is fluent capable to solve with polyhedral elements robustly? Anyone studied about results difference for tetra and polyhedral mesh. Your comments are appreciated!
With regards, JSM |
September 16, 2015, 12:57 |
#2 | |
Rep Power: 18 |
September 16, 2015, 13:32 |
JSM
Rep Power: 20 |
Yes. It is available for long time. But I am not sure, solver and discretization equations can handle polyhedral elements and produce accurate results. Because of this, I hesitate to use polyhedral elements til now.
If someone did correlation study with tetra and polyhedral mesh, then it will be interesting to discuss.
With regards, JSM |
September 16, 2015, 17:40 |
#4 | |
Arjun
Rep Power: 34 |
Do yo u know any code that can do accurate polyhedral treatment? |
September 16, 2015, 22:12 |
JSM
Rep Power: 20 |
I think, Star CCM+ has polyhedral element treatment. But I don't know about Fluent. That is what I would like to know.
With regards, JSM |
September 16, 2015, 22:18 |
#6 | ||
Rep Power: 18 |
September 16, 2015, 23:45 |
Lucky
Rep Power: 66 |
As others have mentioned, Fluent has supported the ability to solve polyhedral meshes for a long time and even has built-in support to convert tetrahedral mesh to a polyhedral one.
One of the niceties of having an unstructured solver is that the solver doesn't care what the grid geometry is. Unfortunately, for the same reason, it's difficult to implement higher order discretization schemes and that's why you're typically limited to 1st or 2nd order upwind schemes. The only things that would affect the robustness are things like cell skewness or area-to-volume ratio, but those problems are general and apply to all grid types. In other words, it really doesn't matter whether your cell is hexahedral with 6 faces or 5 faces or 7 faces or 12 faces. |
September 17, 2015, 09:26 |
JSM
Rep Power: 20 |
Thank you for comments - Antanas & LuckyTran. I understood your points.
Have you used polyhedral elements and compared the results?
With regards, JSM |
September 17, 2015, 10:08 |
#9 |
Rep Power: 18 |
September 17, 2015, 11:22 |
#10 |
Arjun
Rep Power: 34 |
September 17, 2015, 11:23 |
#11 |
JSM
Rep Power: 20 |
How it is worked for you? Do you got accurate results than tetra mesh? And do you compared with test?
With regards, JSM |
September 17, 2015, 11:29 |
#12 |
JSM
Rep Power: 20 |
I never had chance to compare Fluent vs ccm+ with polyhedral mesh. But I should try polyhedral mesh in fluent and compare with test data.
With regards, JSM |
September 17, 2015, 11:55 |
#13 | |
Bharat
Rep Power: 14 |
Regards, Bharat
chapter 3: -crossing the threshold- |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Polyhedral mesh has many more celle than standard mesh | klausb | enGrid | 2 | March 16, 2015 08:01 |
Polyhedral mesh in Fluent | Shri | FLUENT | 3 | August 22, 2007 04:31 |
