Conection over cylinder
Old   September 19, 2015, 07:08
Default Conection over cylinder
vignesh.r
mrvignesh91 is on a distinguished road
CONVECTION OVER CYLINDER......I want to calculate nu at particular angle of cylinder(45,90,180,270) please any one help.......
mrvignesh91 is offline   Reply With Quote
Old   September 19, 2015, 11:22
Lucky
Is that a single point or a line? Create a point or line at those locations and then you can report just the Nu along the point/line. You can also make a monitor.
Old   September 21, 2015, 11:02
vignesh.r
thank yuuu
Old   September 22, 2015, 06:42
Default udf code
vignesh.r
i want udf code for this condition....i want to fluent analyis in regenrator....in pipe fluid having left side as inlet for particular period after that fluid inlet has to be given at right side. ..like this inlet conditon has to be varied over 50 cycles,....please any one help me for the udf code.....
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 16:16
Forces Acting on a Rotating Cylinder (Moving Mesh) dreamchaser CFX 5 April 25, 2015 06:01
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 03:56
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
