September 22, 2015, 20:07 |
Open Channel Initialization by commands
Daniel Coelho
Rep Power: 14 |
I am trying to run Fluent guided by commands, but when I try to initialize the solution by the command "/solve/initialize/open-channel-auto-init 19 yes" (19 is the pressure-inlet BC zode ID) but when I do that the solution is different than when I use the GUI. Does someone know how to correct this?
September 22, 2015, 22:41 |
Lucky
Rep Power: 66 |
I think you need to do a compute-defaults beforehand
Also you can use list-defaults to check and see if your initial conditions make sense. |
September 22, 2015, 22:52 |
Daniel Coelho
Rep Power: 14 |
Thank you very much! That worked well!
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
Yacht in Open Channel Flow | andreimour | FLUENT | 1 | October 14, 2010 23:54 |
