How to Get the Graph of "Degree Vs Nu" in fluent |
November 19, 2010, 01:44 |
Jugal
Rep Power: 15 |
I am performing analysis on "FLOW AROUND CYLINDER"
I am getting xy plot of Nu Vs Direction vector & Nu Vs curve length in fluent. But I need these graph as Nu vs angle on cylinder (theta(/)). How can I plot this type of graph? say Any quantity i.e. Nu, Cp, h vs Angle {theta(/)}? for your reference attaching here 2 figs. I have run analysis on Re.100 and Re.200 & I want to know that how to get recirculation length and separation angle from fluent? Please reply soon... its urgent.. Thx. in advance... |
November 19, 2010, 04:58 |
Khairy
Hi Jugal,
if you plot any variable ( plot--> xy plot) against the curve length (the abscissa), and the line at which you plot is around the cylinder, the abscissa is (radius x theta) so if you write this xy plot to a file you can simply divide the curve length (the first column in the file) by cylinder radius then multiply by 180/pi to have theta in degrees. you can perform this in Excel or write any simple code to perform this simple calculations. If you are aware with custom field function in FLUENT you may use it instead. May be there are many other solutions. but this method works well with me. Regards, Khairy |
November 19, 2010, 06:47 |
Thx khairy
Jugal
Rep Power: 15 |
its worked well within my case too...
Thx.. good bye |
October 2, 2015, 03:47 |
#4 | |
N B Khan
Rep Power: 12 |
I am also studying the flow around cylinder. When I plot the wall shear against the cylinder curve.... the plot appear as shown in image 1...but I want to plot the wall shear against the thetha...so according to your suggestion I export the data in excel form but when I plotted the result there..the chart is very different then the CFX post plot... please help me to make this point clear... When I tried to transfer that data to thetha...it also not work.. Please explain it In my case study Diameter of cylinder is 0.1m,,,so how it can be converted to angle if I want to plot it |
October 2, 2015, 08:34 |
#5 | |
Lucky
Rep Power: 66 |
October 3, 2015, 02:04 |
#6 | |
N B Khan
Rep Power: 12 |
It was so simple thing, but I was stuck in that... Really love this forum ...specially the senior of this forum are really helpful. |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 04:16 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 02:44 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
