Convergence difficulties
Old   November 27, 2015, 08:13
Default Convergence difficulties
vgrzv is on a distinguished road
Hi everyone!
I have an issue regarding the convergence difficulties in Fluent. My case is 2d axisymmetric single stream nozzle. The mesh I was given and its quality is good. I use k-eps model. My solution converges with inlet velocity 1 m/s (pic1) and I can suppose that mesh is fine, but when I set inlet velocity to 10 m/s or higher fluent doesn't converges it (pic2).
I tried several attempts to fix it but still haven't found the solution. Maybe some of you guys has experienced it or knows how to deal with that?
Thank you!
Really appreciate your help!
vgrzv is offline   Reply With Quote
Old   November 30, 2015, 17:49
Cocofeliz is on a distinguished road
Hi!
Have you checked the y+ values?
Cocofeliz is offline   Reply With Quote
Old   December 2, 2015, 12:06
Thank you for your reply!
On the picture attached my Yplus values after converged solution at inlet velocity 20m/s.
I'm trying to increase the speed as I have to end up with Mach 0.85.
In order to refine the grid I adapted Yplus values (30<y+<60), however I'm still struggling as my solution is not converging with increased velocity and Yplus seems to be at the desired range
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Convergence Difficulties sarath CFX 2 August 21, 2006 08:35
Convergence difficulties Freeman FLUENT 1 November 28, 2005 15:42
