Multiphase flow of nanofluids - Low Nusselt number problem
Old   October 30, 2015, 02:26
Default Multiphase flow of nanofluids - Low Nusselt number problem
Aarthy Meena's Avatar
Aarthy Meena
Aarthy Meena is on a distinguished road
Hello Everyone,
Am Aarthy, I am new to FLUENT.
I am modelling 2-D flow and heat transfer of nanofluids around an unconfined square cylinder for my M.Tech project. Initially, I tried a single phase flow using effective property models for properties of nanofluids. Those simualtions are fine and gave comparable results with the literature.
Now, I am trying to use multi-phase flow model. I am trying with mixture model in FLUENT. I tried with particle volume fraction as 0 (i.e., pure basefluid), and I got good values of Nu and drag coefficients which matched with literature.
When I increased the particle volume fraction, the values of Nu and C_D decreased. But, it is well known that, when particle volume fraction is increased, C_D and Nu will increase.
So I am stuck with this. Kindly, pls help me very urgent....
Aarthy Meena is offline   Reply With Quote
low nusselt number, mixture model, multiphase flow, nanofluids
Multiphase flow of Nanofluids - Low Nusselt number problem Aarthy Meena FLUENT 5 January 6, 2016 12:03
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
Nusselt Number problem A7A FLUENT 1 May 24, 2015 12:17
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 14:53
there is a problem with fully developed Nusselt number eeman Fluent UDF and Scheme Programming 4 September 24, 2012 01:36
