How to model and internal pump?
Old   January 15, 2016, 09:02
Post How to model and internal pump?
ujjawal aggarwal
aeroujj is on a distinguished road
I am doing a project in which I want to model flow in a device with a centrifugal pump fitted to cause all the flow. The device also has openings to the atmosphere. I have to basically model the effect of the pump on the fluid and not the insides of the pump. I am a newbie to fluent but I have simulated for the same project in Autodesk Simulation CFD also. I came to fluent because my institute has a licence for it and also fluent has axisymmetric swirl model available(mine is this case). In Sim CFD I used to define the pump domain MATERIAL as a centrifugal pump. Also I only had to give mass flow rate input. In fluent there is no such thing as defining the material as "centrifugal pump" so I suppressed the geometry and applied velocity inlet BCs to the corresponding edges. But this causes the continuity residuals to stay large(round off errors in velocity inlet input). Is there a better way to do this? Will there large continuity residuals really cause that much trouble or have negligible effect? Also my model runs fine with k-omega SST model but diverges for the reynolds stress model(fluent manual suggests RSM for high rpm swirl flows), so is it due to this velocity inlet thing?
Please help
aeroujj is offline   Reply With Quote
internal pump
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Advice on turbulence model for complex internal flow JPBodner Main CFD Forum 1 September 3, 2011 03:07
Internal CFD on a surface model (SW2010) sw1990 Main CFD Forum 7 January 4, 2011 19:36
turbulence model in internal combustion engine George Main CFD Forum 0 December 4, 2006 18:01
