November 7, 2015, 12:49 |
Setting Surface Tension in TUI
CWL
Rep Power: 10 |
Does anyone know how can I set the surface tension in the journal file for VOF calculation in FLUENT? I tried searching on the internet (for hours) and found this: solve/set/surface-tension, but it seems that it is setting the numerical solver and not the value of surface tension. Any ideas? Thx.
November 9, 2015, 00:14 |
Lucky
Rep Power: 66 |
It's best to learn for yourself how the TUI works.
Check the Fluent manual for a list of all TUI commands. Or press enter into the TUI and you'll get a list of currently available commands. The TUI commands are very similar to the steps you go through in the GUI. |
November 10, 2015, 07:05 |
#3 | |
CWL
Rep Power: 10 |
multiphase, surface tension, vof |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
surface tension gradient using UDF; surface tension gradient as function of temperatu | marimuthusundar | Fluent UDF and Scheme Programming | 0 | June 21, 2012 04:48 |
Surface tension problem. | Kes | FLUENT | 0 | May 19, 2008 22:49 |
Surface Tension Force Model | Miguel | CFX | 7 | October 2, 2006 05:30 |
surface tension model in EX26 | Junhua Wu | FLUENT | 0 | June 7, 2000 10:49 |
