Compressible flow in vacuum condition
Prev Previous Post   Next Post Next
Old   December 2, 2015, 19:48
Default Compressible flow in vacuum condition
Hamid
aerocfd is on a distinguished road
So I am trying to simulate a train in a tunnel in a vacuum condition.
First Question, Do I need to always consider compressible flow? or is compressible flow only for velocities of greater than mach 0.3 ?
Second Question, if I want to model it as compressible flow, for the boundary condition if I use pressure-inlet then how do I make my train move in the flow? because by using velocity-inlet which I suppose is for incompressible flow you can give magnitude and direction and keep the train stationary.
Thank you for your time.
aerocfd is offline   Reply With Quote
How to set the velocity inlet boundary condition in the compressible flow? lienien FLUENT 2 March 11, 2013 08:25
Compressible Flow problem verma_rahul Main CFD Forum 0 June 2, 2012 18:36
About compressible flow at low mach hit Main CFD Forum 2 October 26, 2009 21:21
periodic condition for compressible flow ricklee Main CFD Forum 1 November 15, 2006 00:23
Solving unsteady compressible low speed flow atit Main CFD Forum 8 July 31, 2000 13:19
