Residual becomes unstable when second order upwind is set
Old   December 31, 2015, 11:03
Default Residual becomes unstable when second order upwind is set
jexposito is on a distinguished road
I was trying to simulate a 2D symmetric problem in fluent. However, I found a problem when I set second order upwind, I started the simulation with first order upwind, then when I achieve 1e-5 in residuals I set to second order upwind but I have the problem showed in the following figure. Can anyboy help me with this?
Thank you in advance.
jexposito is offline   Reply With Quote
Old   December 31, 2015, 13:29
B_Kia
HyperNova is on a distinguished road
hi
the trend is converging, so i think it is ok
HyperNova is offline   Reply With Quote
Old   December 31, 2015, 13:41
Yes, it seems like the trend is convergin but it will need many more iterations and I do not know if the accuracy of the solution will be affected by this unstability. Does anybody know how could I alleviate this affect?
The problem is a supersonic problem, with air as ideal gas using a density based approach.
Thank you in advance and regards.
settlingFoam unstable? bendel_boy OpenFOAM Running, Solving & CFD 38 July 8, 2016 05:07
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
Why RNGkepsilon model gives floating error shipman OpenFOAM Running, Solving & CFD 3 September 7, 2013 08:00
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
