Acoustic Simulation in Fluent (Pre-defined sound source)
Old   October 30, 2012, 00:42
Default Acoustic Simulation in Fluent (Pre-defined sound source)
sam
bassam693 is on a distinguished road
As we know, in Fluent (with acoustic model turned on and by using the FWH solver) we can set surfaces as sound sources in order to calculate acoustic data (ex: dpdt RMS) at them, and to calculate sound pressure level at some predefined receivers. In addition to that, I need to include some predefined sound source; for example, i need to specify a surface that is already emitting sound (constant sound pressure level in dB) even before taking into consideration the simulation that will go on.
More specifically my problem in the following:
I'm running a simulation around an aircraft and i'm interested in the acoustic field at its airframe and the SPL at some receivers. However, in addition, I would like to have the engine emitting sound with constant SPL (dB) during the whole simulation. The point of the simulation is to see how the engine sound affects the acoustic field that is generated from the flow itself. Is that possible ??? thank you in advance.
bassam693 is offline   Reply With Quote
Old   January 2, 2016, 07:06
Default fluent jet acoustics
kabilan.B
kabilan is on a distinguished road
hai,
please help me for acoustic modelling in fluent.
i am doing jet acoustics for that i made modelling and meshing in gambit ie jet
from pipe.
in fluent i am using FWH for acoustic in that to define source what should i have to give but it show wall but ii need jet as source.
please help out this problem.
thank you
kabilan is offline   Reply With Quote
flapping wing simulation in fluent Carlen Fluent UDF and Scheme Programming 2 October 23, 2017 04:32
Radiosity-FEM method - light source simulation zeluizfb CFX 3 August 14, 2012 17:37
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
Fluent simulation over airships Aragon FLUENT 8 March 30, 2009 12:12
