fresher in heat transfer and solar load model |
January 30, 2014, 09:34 |
Rep Power: 14 |
My case is that a 3d building situated within an air domain. I have done the solar calculation. I confused about How to set the thermal and radiation boundary condition of air walls. Opaque or semi-tranparent? I tried to select semi-transparent and set all the terms in transitivity section in 1, but I'm not sure is it correct? For the 3d building, I applied subtraction to remove solid body from the air domain, so finally only the surface of building left. I wonder how to work out the external emissivity and heat transfer coefficient if I put those thermal condition in the air wall. Another question is that if we assume a people inside the air domain, there must be a heat generation rate. What's the typical value of heat generation rate of people and for the mesh of people, do we just put a small-volume cube inside the domain and set each side with same heat generation rate?
Look forward to hearing from you Thanks in advance |
April 2, 2015, 15:27 |
ray tracing simulation of Solar parabolic dish concentrator
Mechanical Enginnering
does anyone know how I can help CFD software (SOLAR LOAD, SOLAR RAY TRACING) computed flux of radiation absorbed solar parabolic dsih concentator in its focal plane of absorber spiral pipe receiver?
Thank you very much Sasa |
November 9, 2015, 02:14 |
Johnny
Rep Power: 11 |
Hi, @Sarica 10092.
May i ask that do you can solve this problem? I'm also facing the same problem now? May you share some knowledge with me? Thank you. |
January 2, 2016, 02:04 |
#4 | |
Johnny
Rep Power: 11 |
Thank you. |
January 11, 2016, 12:12 |
#5 | |
R-Sh
Rep Power: 11 |
May I please ask how did you do solar calculation? In my case, No matter what I put for direct solar irradiation and diffuse solar irradiation, I get 0 for solar loading. Any help will be greatly appreciated! |
Heat transfer in a flat solar panel | Tramph | FLUENT | 1 | January 2, 2016 01:59 |
heat transfer in solar air heater | arunachalam.siva | FLUENT | 3 | April 17, 2013 14:43 |
Simulating Heat Transfer in a Parabolic Trough concentrating Solar collector receiver | Ash_Mech_Eng | FLUENT | 1 | December 10, 2012 11:02 |
Heat transfer simulation with low-Re modelling blowing up | cm_jubayer | OpenFOAM Running, Solving & CFD | 4 | June 19, 2012 09:49 |
Modeling the flow of solar radiation as the heat flux from the surface. | Gebbels | FLUENT | 0 | March 25, 2012 14:39 |
