fresher in heat transfer and solar load model
Like Tree1Likes
  • 1 Post By sarica 10092
Old   January 30, 2014, 09:34
Default fresher in heat transfer and solar load model
itsme_kit is on a distinguished road
My case is that a 3d building situated within an air domain. I have done the solar calculation. I confused about How to set the thermal and radiation boundary condition of air walls. Opaque or semi-tranparent? I tried to select semi-transparent and set all the terms in transitivity section in 1, but I'm not sure is it correct? For the 3d building, I applied subtraction to remove solid body from the air domain, so finally only the surface of building left. I wonder how to work out the external emissivity and heat transfer coefficient if I put those thermal condition in the air wall. Another question is that if we assume a people inside the air domain, there must be a heat generation rate. What's the typical value of heat generation rate of people and for the mesh of people, do we just put a small-volume cube inside the domain and set each side with same heat generation rate?
Look forward to hearing from you
Thanks in advance
itsme_kit is offline   Reply With Quote
Old   April 2, 2015, 15:27
Smile ray tracing simulation of Solar parabolic dish concentrator
Mechanical Enginnering
sarica 10092 is on a distinguished road
does anyone know how I can help CFD software (SOLAR LOAD, SOLAR RAY TRACING) computed flux of radiation absorbed solar parabolic dsih concentator in its focal plane of absorber spiral pipe receiver?
Thank you very much
Sasa
Johnny leow likes this.
sarica 10092 is offline   Reply With Quote
Old   November 9, 2015, 02:14
Johnny
Johnny leow is on a distinguished road
Hi, @Sarica 10092.
May i ask that do you can solve this problem? I'm also facing the same problem now? May you share some knowledge with me?
Thank you.
Johnny leow is offline   Reply With Quote
Old   January 2, 2016, 02:04
Johnny
Thank you very much
Sasa
Thank you.
Old   January 11, 2016, 12:12
R-Sh
shadnia is on a distinguished road
Thanks in advance
Dear Ke
May I please ask how did you do solar calculation? In my case, No matter what I put for direct solar irradiation and diffuse solar irradiation, I get 0 for solar loading. Any help will be greatly appreciated!
shadnia is offline   Reply With Quote
Heat transfer in a flat solar panel Tramph FLUENT 1 January 2, 2016 01:59
heat transfer in solar air heater arunachalam.siva FLUENT 3 April 17, 2013 14:43
Simulating Heat Transfer in a Parabolic Trough concentrating Solar collector receiver Ash_Mech_Eng FLUENT 1 December 10, 2012 11:02
Heat transfer simulation with low-Re modelling blowing up cm_jubayer OpenFOAM Running, Solving & CFD 4 June 19, 2012 09:49
Modeling the flow of solar radiation as the heat flux from the surface. Gebbels FLUENT 0 March 25, 2012 14:39
