Calculate flow
Old   January 12, 2016, 05:46
Default Calculate flow
maroua
maroua2016 is on a distinguished road
I want to calculate the flow in a pipeline. I need numerical approach like Finite Element Method, Finite Volume Method, Finite Difference Method or Method of Characteristics.
Please, could you advise me what is the better method to use?
Thanks
maroua2016 is offline   Reply With Quote
Old   January 12, 2016, 15:10
Lucky
Method of Characteristics is difficult to apply to a dissipative problem like viscous flows (it's very hard to find the characteristics).
For a regular cartesian grid, finite differencing is doable. For irregular grids also doable but there might be pain in some parts of your body.
For grids with funny cell shapes you need to be using either Finite Element / Finite Volume method. It's hard to discretize the problem for grids with funny shapes using the other methods.
There are fair reasons to choose FEM vs FVM, for example FVM results in a sparse system, which you can exploit with certain algorithms but it also has some drawbacks.
Fluent is based on Finite Volume Method.
finite difference method, finite element method, finite volume method, method of characteristics
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Possible to calculate the flow profile across flat plate? midnightblack Main CFD Forum 1 March 15, 2015 10:58
[OpenFOAM] calculate flow rate (artery geometry) vitorspadetoventurin ParaView 3 January 2, 2015 07:44
You can calculate the pressure drop in two-phase flow? example, slug flow or stratifi Mechaniker FLUENT 0 December 22, 2014 11:04
calculate volume flow from a 2D simulation SimonH. OpenFOAM 0 October 27, 2009 04:39
