January 13, 2016, 03:29 |
Simulation always stops after 1000 seconds
Zerzura
Rep Power: 10 |
Good day everybody,
Every time my transient simulation passes the 1000 seconds it stops. There is no divergence, it just finishes the last iteration and sends the message: " Flow time = 1012.8s, time step = 29 971 more time steps > adapt/ file/ report/ define/ mesh/ solve/ display/ parallel/ surface/ exit plot/ views/ > /file/write-case-data > exit" It knows there are still 971 time steps to go, why does it stop iterating? I already checked my Max-time-on-flow and it is on "unlimited". I work on the cluster. Your help is much appreciated! Kind regards |
January 13, 2016, 09:48 |
post the full input and submission files you submit to the cluster.
January 13, 2016, 09:51 |
Zerzura
Rep Power: 10 |
Thank you very much for you answer!
I already solved the problem with help from a friend. The answer is, by putting an adaptive-time-stepping method and use a UDF for time-steps, the setting for you ending-time is set to 1000 seconds by default. You have to change this as well, so not only the max-time-on-flow. Kind regards |
cluster, maximum, time-on-flow |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Unfinished particle tracks in simpleReactingParcelFoam | Cornelia | OpenFOAM Running, Solving & CFD | 3 | June 5, 2015 03:58 |
rhoSimplecFoam Mach0.8 no pressure values | CFDnewbie147 | OpenFOAM Running, Solving & CFD | 16 | November 23, 2013 05:58 |
Simulation stops too early in paraView?? | umassche | OpenFOAM | 2 | February 18, 2011 00:05 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
