how to obtain pathline for particle in unsteady problem?
Like Tree2Likes
  • 1 Post By sidoubouzareah
  • 1 Post By hwet
Old   December 27, 2015, 04:04
Thumbs down how to obtain pathline for particle in unsteady problem?
mohammad
mostanad is on a distinguished road
hi, we are solving an unsteady flow over a cylinder. we want to obtain the pathline for some particular particles.... but we don't know how to start.... is anybody help me?
mostanad is offline   Reply With Quote
Old   January 12, 2016, 09:31
sidoubouzareah
sidoubouzareah is on a distinguished road
have the same problem fazli, i don't know how to do it!!!
salam
mostanad likes this.
sidoubouzareah is offline   Reply With Quote
Old   January 12, 2016, 16:11
Dave M.
Dave_88 is on a distinguished road
If you simply want some pathlines:
Results>Graphics>Pathlines
Select the boundary condition, from which you want to start your pathlines, for example inlet. Then click on display. Modify the lines by increasing step size, steps or path skip.
You also may color the pathlines by certain quantities such as velocity.
Dave_88 is offline   Reply With Quote
Old   January 13, 2016, 03:57
Default Particle pathlines.....
sidoubouzareah
Thank you very mutch Dave, actually i want to use " export to CFD-post" to tracke the particules trajectories.
In fact, in the Cdf-post, i can display the counters, the velocity fields... but the particles pathlines and tracke trajectory doesn't work.
Just to make you in, it's a rotating cylindre full of viscous fluide (continous phase), in witch we inject from the battom bubbles (dispersed phase of air).
So we want racking the trajectory of bubbles to confirm the rotational particles pathlines in the fluide vortices.
Thanks again Dave,
Best regards.
Old   January 13, 2016, 09:47
hwet is on a distinguished road
you need to export particle tracks from fluent then read them in cfdpost as fluent particle tracks
hwet is offline   Reply With Quote
Old   January 13, 2016, 10:03
sidoubouzareah
Hi Hwet, thank you for your answer,
I do realise exporting particle tracke fluent "*.xml", and import it by cfd-post, but when i wanted to display particle track , or treamlines on cfd-post, it shows only the particles positions as points.
thanks again,
Old   January 13, 2016, 10:58
It should not be writing a new file for every time step but updating the file each time.
Do see if this is being done correctly, notice how the size of the particle file being written increases as the simulation proceeds. it will increase from a few kb to 100s of kbs and so on with time.
If not, it means that the particle file is not being saved properly. I have had this problem before. Dont have Ansys right now to tell you the exact process to save the file correctly.
sidoubouzareah likes this.
Old   January 13, 2016, 11:26
sidoubouzareah
thanks again,
There is other thing, when i want de display the particles track, i have to selesct " method> from file > Browse file " *,trk". I can't do it because the droplet " from file" contains only "from file ", and this file *,trk does not exist.
I think the particles track of fluent is not saved properly as you said.
I preciate your help;
Old   January 13, 2016, 14:56
mohammad
actually i have the problem at first... in particle tracking for transient solutionn... how it can be done??? when you say dpm phase!!!
Old   January 14, 2016, 04:01
sidoubouzareah
hi Fazil, go to Models>Discret phase model>injections and you have to put your différents parameters as: droplet or inert bubble, position of injection, flow rate, velocity of injection, and also choose teh materials of bubbles from data base.
hope it helps you freind;
Old   January 15, 2016, 14:46
mohammad
now i track the particles... i want track prticular particles... or two normal elements and obtain the change of angle between them... how i can do these works???
Problem with implementing unsteady Kutta condition-Hess and Smith Panel method samarthgk.nitk Main CFD Forum 0 June 25, 2012 02:36
how to compare unsteady state problem results from FLUENT with Experimental data? cuddaloreselvam FLUENT 0 July 10, 2011 08:25
Under Relaxation Factors(URF) in unsteady problem Maxmum FLUENT 0 August 14, 2010 18:00
Unsteady problem girishom CFX 7 July 15, 2009 12:46
Question concerning about unsteady problem.... ghlee Main CFD Forum 6 October 2, 1998 05:36
