January 5, 2016, 10:02 |
Fluent profile reading for another solution
Ozge
Rep Power: 14 |
Hello all,
I need help with a problem. I have an aircraft simulation series. The main geometry is the same: same fuselage same wing with little differences, i.e. aileron angle, flap etc. The fuselage is very detailed and the mesh size is quite big as is. I want to use the results from a full size analysis and solve the other ones with smaller mesh, without using fuselage and farfield. I have written a profile for the cross-section I want from the full-size analysis result and read it into the new mesh boundary. However, what boundary type should I use for this? If I use pressure inlet, I can specify pressure and temperature but velocity directions are off. Velocity-inlet does not work at all (absurd pressure values). Is this doable? How can I do it? Btw, it is compressible flow, k-w SST 0.2 Mach. |
January 6, 2016, 15:44 |
Lucky
Rep Power: 66 |
If you want to specify as many parameters as possible then you should be using velocity inlet and specifying, x,y,z velocity, temperature, and turbulence.
January 7, 2016, 04:35 |
Jordi Pina
Rep Power: 11 |
I'm facing someway the same problem and I have the following problem: http://www.cfd-online.com/Forums/flu...-attached.html Maybe it inspires you... I'm using velocity inlet and a UDF which interpolates values from the macro simulation for setting the velocity in the coordinates x and y. Thanks! |
January 22, 2016, 07:26 |
Ozge
Rep Power: 14 |
Thanks for the replies guys. Sorry, urgent jobs came in the way and i couldn't reply quickly.
I will try and play around a bit with velocity inlet but will it be numerically correct? I mean my flow is compressible and fluent says velocity inlet is not very good for comp. flows. |
boundary condition, fluent, profile |
Invert profile in fluent? | Stormbringer505 | FLUENT | 2 | October 19, 2015 03:43 |
Cht tutorial in 15 | braennstroem | OpenFOAM Running, Solving & CFD | 197 | June 10, 2015 03:02 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 10:45 |
Can Fluent handle a degenerate block? Error while reading mesh... | Anorky | FLUENT | 1 | May 1, 2010 12:47 |
problem when converting mesh (made by ICEM) using fluentMeshToFoam | Forrest_Lei | OpenFOAM | 11 | October 16, 2009 06:28 |
