simulation of a rotary positive displacement pump
Old   February 1, 2016, 06:39
Default simulation of a rotary positive displacement pump
Ken
kennyboy is on a distinguished road
Hi guys,
I am facing a problem with my simulation which I was hoping that someone can advise me about.
Long story short: the fluid flows from outlets to inlets instead.
My rotary positive displacement pump has the same mechanism used by the wankel engine. The fluid I am using in this simulation is engine oil as this pump is meant for pumping engine oil.
What I did in FLUENT is I gave my inlets and inlets a boundary condition of 1.5bars at the inlet and 1.8 bars at the outlets. Because I am expecting the actual pump prototype in my lab increases the pressure of the engine oil running through it by 0.3bars.
However, the pressure boundary conditions instead made the engine oil flow from the outlets to the inlets (from a region of higher pressure to a region of lower pressure).
So this simulation doesnt depict how the rotary mechanism increases the pressure of the fluid but rather how the fluid flows naturally from a region of higher pressure to a region of lower pressure despite the presence of the rotor.
So I was hoping someone can enlighten me about this issue.
Thank you very much in advance!
kennyboy is offline   Reply With Quote
ansys, fluent, pressure, pump, pumps
Rotary Vane Vacuum Pump nausheensultana FLUENT 0 March 27, 2015 09:38
Flow simulation in Axial Pump Impeller aungkyaw Main CFD Forum 1 December 9, 2014 02:02
NPSHr 3% in pump simulation pump_passion CFX 6 August 7, 2014 08:33
problem for centrifugal pump transient simulation renyun0511 OpenFOAM Running, Solving & CFD 8 January 15, 2014 04:55
Vacuum pump simulation Alasdair Main CFD Forum 3 March 3, 2011 00:00
