February 11, 2016, 01:55 |
Temperature for Centrifugal compressor
Singapore
Rep Power: 10 |
Wish to consult on a matter regarding the boundary conditions for temperature for my centrifugal compressor. I am trying to compute the isentropic efficiency of a centrifugal compressor and I have been able to get the pressure work done on the fluid. However, I am unable to get the temperature changes. I have turned on energy model. My current set up is based on a pressure solver. I am using mass flow inlet and a mass flow outlet since I have a target mass flow rate in and out provided to me. Could someone kindly advise if there are any settings that I need to enable to get the temperature results? Thank you! Nic |
UDF for Back-flow Temperature | G340 | Fluent UDF and Scheme Programming | 3 | August 21, 2013 04:56 |
Turbocharger Compressor Wheel CFD Analysis | aymen_a22 | ANSYS | 1 | April 20, 2013 10:39 |
[TurboGrid] Turbocharger Compressor Wheel Meshing | aymen_a22 | ANSYS Meshing & Geometry | 0 | March 20, 2013 10:27 |
Too low temperature at combustor outlet | romekr | FLUENT | 2 | February 6, 2012 10:02 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
