Setting Initial Temperatures of Cell Zones, Help Needed |
February 26, 2016, 02:14 |
Rep Power: 10 |
I have been trying to set different initial temperature for two adjacent fluid cell zones to conduct a transient density driven analysis of their mixing. My first basic approach is to consider creating a register for each cell zone and then patch the temperature. As Fluent is rather new to me, how do I ensure that I capture all of the cells from each cell zone? Maybe a more simpler question: how can I move a vertex of my geometry to the origin so that I can appropriately set/mark the region bounds? Thanks! Last edited by UWBCFD; February 26, 2016 at 02:17. Reason: Change of title |
March 3, 2016, 01:25 |
Figured out how to patch the cell zones.
Rep Power: 10 |
In my case I was conducting a density driven transient study. I wanted to observe the natural convection at interface of two different temperature fluids interacting with one another.
To set initial conditions of the cell zones: 1) Make sure each cell zone is clearly defined 2) Initialize the hybrid case 3) Select the desired cell, click and set desired initial temperature 4) Repeat process for additional cell 5) Unfortunately, ANSYS Fluent does not clearly state what the patched temperature of each zone is so it can be confusing at times but trust that each zone's temperature is set. |
adaptation, fluent 16.4, mark, region, region adaptation |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
