February 27, 2016, 14:15 |
y+ problem
cglr
Rep Power: 11 |
Hello, I had to post this thread again in case some new readers may help.
I have a simulation that consist of two parallel heated wall and blowing air between them. Flow is turbulent and attached picture, you can see the y+ contours on one of two walls. Although y+ value should decrease along x direction as flow gets developed, there is a region that shows an increasing. ( I enclosured in the picture). For this reason I have a heat transfer coefficient distribution that decreases from start point naturally but increases at that region then decreases again after that region. What may cause this region ? I need to get rid of that meanless region. |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
