How to obtain radial force distribution graph from FLUENT? |
March 3, 2016, 03:32 |
numan
Rep Power: 11 |
Hi guys,
I simulated a wind turbine blade (NREL Phase VI) in FLUENT. I need to draw the dimensionless radial force distribution along the blade (as in the attached picture). I know that I need to obtain radial force distribution along the blade first. How do I obtain it? Do I need to add a surface or a line along the Y axis (see attached Fluid Domain) in ANSYS Results? If yes, in which side of blade should it be (there are two sides)? Thank you |
March 4, 2016, 16:58 |
numan
Rep Power: 11 |
no one?
March 29, 2016, 10:04 |
numan
Rep Power: 11 |
I still couldn't make it, anyone can help?
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
Force Contour Plots in Fluent 14.0 | lew | FLUENT | 0 | May 31, 2013 09:29 |
Surface tension force expression at the wall in fluent | IndrajitW | FLUENT | 0 | April 15, 2013 08:37 |
Fluent Force Report | maharvey | FLUENT | 2 | April 12, 2010 13:06 |
Some help simulating Magnus Force using Fluent | Michele Spinolo | FLUENT | 6 | June 27, 2002 12:57 |
