February 18, 2016, 01:38 |
how to feed governing equation in fluent
Pradip
Rep Power: 10 |
i m trying to calculate lift of a cylinder in a 2D flow using viscous laminar model but i m not getting correct magnitude of the answer.. i doubt the system is not using the correct governing equation... how do i know what governing equation fluent is using in viscous laminar model and how can i modify it if required??
February 18, 2016, 05:53 |
#2 | |
Bruno Machado
Rep Power: 12 |
February 18, 2016, 06:32 |
Thanks
Pradip
Rep Power: 10 |
Bruno Machado,
Thank you very much for your timely reply. |
February 21, 2016, 23:46 |
Pradip
Rep Power: 10 |
hi bruno machado
looked into the help but it does not show governing equation for the viscous and the laminar flow... it shows the governing equations for the rest....guess i need to take some udf lesson.... anyways thanks for ur attention and advice.... |
February 22, 2016, 06:43 |
#5 | |
Bruno Machado
Rep Power: 12 |
you can find it here http://aerojet.engr.ucdavis.edu/flue...ug/node382.htm regards |
March 3, 2016, 13:16 |
Pradip
Rep Power: 10 |
hi bruno
can u help me by telling how to make a laminar model also incompressible?? i m not getting correct solution... thanks |
March 3, 2016, 15:59 |
Bruno Machado
Rep Power: 12 |
the you define the density of you material, you can specify which kind of flow it is (compressible, incompressible, real gas, ideal, etc.).
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
How fluent solves an equation!!! | self_shattered | FLUENT | 1 | April 26, 2011 03:07 |
Wave equation for hfss in fluent | jpcfd | FLUENT | 0 | March 16, 2010 10:45 |
governing equation of sliding mesh | torn | FLUENT | 1 | August 10, 2006 03:34 |
Fluent equation error?!? | TOM | FLUENT | 6 | July 15, 2002 03:24 |
