March 5, 2016, 09:01 |
Reference values and initialisation
Kieron
Rep Power: 11 |
I have a case where a container is filled with a phase change material. It is initially a solid (317K), melting when the temperature has reached 319K from the hot wall adjacent. Should I set the reference value for the interior to 317K or even lower than this? Then for initialisation set the hot wall to initially be, say 300K?
I am confused with these two concepts, could someone please elaborate? Regards |
March 5, 2016, 19:47 |
Lucky
Rep Power: 66 |
The initialization is your initial condition. You should know what value to put here (the initial temperature).
The reference values tab is a set of arbitrary values used for post-processing and does not affect the solution in any way. The reference temperature is used for calculating the heat transfer coefficient q" = h*(Twall-Tref). |
natural convection | mehrdadeng | CFX | 10 | February 25, 2011 05:25 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
modify ccmp for initialisation | Thomas Baumann | Siemens | 4 | August 24, 2009 09:35 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 03:30 |
error using combination of step function | xujjun | CFX | 1 | January 15, 2008 16:46 |
