How to set heat transfer coefficient and wall temperature |
March 21, 2016, 03:45 |
Jordi Pina
Rep Power: 11 |
Dear all,
I’m carrying out a conjugate heat transfer coefficient, where I have a meshed solid and a meshed fluid in contact. I want to set a heat transfer coefficient of 5000 W/m^2/K and a fixed wall temperature. However, in the convective heat transfer options, eventhough I can choose the heat transfer coefficient, I cannot set the wall temperature, but the free stream temperature. How could I set a fixed wall temperature and a heat transfer coefficient? Thanks a lot. |
March 21, 2016, 08:47 |
Jordi Pina
Rep Power: 11 |
For a fixed temperature BC,
(7.3-47) where =fluid-side local heat transfer coefficient=wall surface temperature=local fluid temperature=radiative heat flux But I want to set myself the hf value! Instead, ANSYS help says: "Note that the fluid-side heat transfer coefficient is computed based on the local flow-field conditions (e.g., turbulence level, temperature, and velocity profiles), as described by Equation 7.3-54 and this equation in the separate Theory Guide. " Which is not what I am interested in! I will appreciate your help... I'm stucked in this... |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
