Nusselt number in ribbed channel.
Like Tree1Likes
  • 1 Post By marluc
Old   May 4, 2012, 04:33
Default Nusselt number in ribbed channel.
A7A
AHMAD
A7A is on a distinguished road
I am simulating a 2d ribbed channel heat transfer problem at (Re=10000 and wall heat flux q=1200 w/m2), and to simplify the solution i simulate half of the channel, but when computing Nusselt number from surface integrals i get a Nusselt number that is half of the right value of Nusslet number. (I am using the air temperature as reference temperature).
This is a picture of the geometry and mesh.
Thank you.
A7A is offline   Reply With Quote
Old   May 4, 2012, 04:45
Yogesh Patil
foamcfd is on a distinguished road
Did you check the reference values in fluent. To report nusselt iot makes use of reference length which is set as default 1 in the refernce values.
foamcfd is offline   Reply With Quote
Old   May 4, 2012, 04:47
A7A
AHMAD
Thank you for your reply,
I used the hydraulic diameter of the channel as length reference value.
Old   May 4, 2012, 12:26
A7A
AHMAD
Any solutions?
Old   May 7, 2012, 09:37
A7A
AHMAD
Is this problem brcause of using standard k-w model, or because of using 2d study instead of using 3d study.
I hope that someone could advice me.
Thank you in advance.
Old   June 8, 2012, 09:12
Luca
marluc is on a distinguished road
the 2D simulation is appropriate for ribbed channels with high aspect ratio (AR=depth x height). Anyway, RANS model hardly give accurate heat transfer results for flows with adverse pressure gradients (and thus recirculation).
You can check this paper:
A. Ooi, G. Iaccarino, P.A. Durbin, M. Behnia, Reynolds averaged simulation of flow and heat transfer in ribbed ducts, Int. Jou. Heat and Fluid Flow, 23, 2002
nenazarian likes this.
marluc is offline   Reply With Quote
Old   June 10, 2012, 08:24
A7A
AHMAD
Thank you for your reply, it was helpful.
Old   August 4, 2012, 01:15
Prem Chand
premchandpendota is on a distinguished road
Hi
Is your problem with the nusselt number solved? The problem i am working on also needs the variations of nusselt number across the area. But i am getting less values as you have mentioned.
If your problem got fixed, could you please tell me the changes i need to make in the numerical model? I have used the reference values just as you have mentioned in the previous posts.
premchandpendota is offline   Reply With Quote
Old   August 4, 2012, 09:49
A7A
AHMAD
The main problem in my study was using 2d study (2d study can't predict the secondary flows that occur in the channel).
But if your study is 3d you could check the paper that marluc suggested, where you will find that also 3d study won't give you the same experimental results.
Old   March 21, 2016, 06:05
Default A problem with calculating nusselt number
hadi
hadial is on a distinguished road
I am new to cfd, And i am sure this question will seem easy to experts,
I am simulating a 3d ribbed channel,
can anyone tell me exactly how should I calculate average nusselt number on ribbs in fluent ??
I use reports---->surface integrals---->area-weighted average---->wall flux ------> surface nusselt number then I chose my ribbed wall and calculate nusselt
Is this ok for calculating average nusselt number ??
I use symmetry bc to simulate half of a channel should i divide result on 2 to get the proper result ??
Your great help will be really appreciated
hadial is offline   Reply With Quote
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
Average Nusselt Number kamran651 FLUENT 8 April 2, 2016 08:41
Nusselt number in microchannel micro77 FLUENT 7 March 3, 2014 13:08
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
