Courant number in steady, coupled solver
Old   April 3, 2016, 23:06
Default Courant number in steady, coupled solver
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Hello everyone,
I am running a steady case with coupled solver. For low values of courant number solution converges is it my final solution should be independent of courant number or can I accept low courant number converged results without further increasing the courant number.
Regards,
Sunil
sunilpatil is offline   Reply With Quote
Old   April 6, 2016, 09:09
Lucky
The Courant number is like an under-relaxation factor. If you increase it you can amplify numerical oscillations that cause your solution to diverge, increasing urf's also does the same.
The low Courant number solution should be okay as long as you didn't put a ridiculously small number for the Courant number. I think the default is now 50 (it used to be 200 in some versions). It's hard to tell if your solution is converged or not with small urf's and Courant numbers. Sometimes people put 1e-6 for their urf's and think they have a converged solution...
Sudden jump in Courant number NJG OpenFOAM Running, Solving & CFD 7 May 15, 2014 13:52
decomposePar pointfield flying OpenFOAM Running, Solving & CFD 28 December 30, 2013 15:05
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
Role of Courant number in Density solver David Christopher FLUENT 0 January 20, 2013 22:18
Courant number for steady state modeling songpen1985 FLUENT 3 October 6, 2009 10:03
