[fluent] Velocity vectors not normal to the boundary |
April 20, 2016, 00:13 |
shuk
Rep Power: 10 |
hello all,
as in pictures attached, i wanted to created a rotating part (yellow) inside a cylinder. so when i input rotational velocity to the rotating part, the vector of velocity on the inlet started to swirl before it even reached the rotating part, arent the vectors suppose to be straight first and rotate when it reach the rotating part? |
April 20, 2016, 00:15 |
shuk
Rep Power: 10 |
when i give rotational velocity of the rotating zone to 0, the vector seems to travel straight
April 20, 2016, 13:45 |
#3 | |
Lucky
Rep Power: 66 |
Navier-Stokes equations are elliptic, information (shear in this case) can propagate upstream. i.e. the downstream rotating fluid can drag the upstream fluid and also cause it to rotate. Laminar flows are dominated by momentum diffusion so this seems applicable. You can do some rough calculations to see if the shear stress is of the right order of magnitude. |
April 21, 2016, 07:22 |
shuk
Rep Power: 10 |
hi luckytran,
thanks for the explanation. btw could you have a look at my mesh file and tell me what i did wrong? |
April 22, 2016, 04:16 |
shuk
Rep Power: 10 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Velocity inlet boundary condition for porous medium | Chander | CFX | 3 | March 11, 2012 21:18 |
CFX does not continue | Shafiul | CFX | 10 | February 17, 2011 07:57 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
