results visualisation of parametric design point analysis |
April 26, 2016, 08:28 |
Tim Kayser
Rep Power: 10 |
at the moment I am analysing the slot geometry of a dual-element wing. Therefore I parameterised the slot geometry and did several runs. Now I'd like to check on each of the results independently in terms of velocity and pressure contours and cp- plot etc. The problem though, I can't find the option where to switch between the design points results. I can reach only the baseline simulation. I'd appreciate any quick help! BTW: I am using Ansys 14.5 Cheers, Tim |
April 27, 2016, 20:27 |
Lucky
Rep Power: 66 |
Just read the data file. You should have saved individual data files for each condition...
April 28, 2016, 09:59 |
Tim Kayser
Rep Power: 10 |
Thanks LuckyTran. Unfortunately looking into the folder I can't find any additional .wbpj files in the of the run, where I computed several design parameters. What do these files look like (file format) and what do I need to set in the Solution Setting in order to receive these additional files?
April 28, 2016, 18:23 |
Lucky
Rep Power: 66 |
There's a .cas file and .dat file. You want the .dat file. Go into Fluent, file read-data or read case and data.
The .wbpj is a workbench project file, which is sort of the workbench equivalent of a .cas file (except a .cas file contains a mesh). The .wbpj file is pretty useless. |
April 29, 2016, 03:34 |
#5 | |
Tim Kayser
Rep Power: 10 |
Perfect. Thanks a lot for your info! |
design points, fluent, parame, reusults |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
[blockMesh] error EOF in blockMesh | Ahmed Khattab | OpenFOAM Meshing & Mesh Conversion | 7 | May 17, 2012 00:37 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
exporting results from fluent for fem analysis | Kevin | FLUENT | 1 | September 13, 2006 15:14 |
Results analysis | Adrian Mawdsley | Main CFD Forum | 0 | March 21, 2003 10:18 |
