June 5, 2020, 12:11 |
Time vs displacement graph
sunil
Rep Power: 6 |
I am simulating a damper in fluent. I have provided mass and acceleration due to gravity.spring constant is also defined.
now I have to plot the displacement vs time graph. even in the report definitions displacement parameters not available. how to create displacement graph? |
June 5, 2020, 16:09 |
Displacement
If you are looking for displacement of the rigid body, then that is written using six-DOF model setting. There is option to write motion history. However, displacement is nothing but the position coordinates. So, you can also write all three coordinates (only one if motion is along one axis) for any one point on the rigid body.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
June 10, 2020, 03:27 |
#3 | |
sunil
Rep Power: 6 |
thank you , it worked for me. |
May 12, 2021, 10:45 |
#4 | |
Maitreya
please don't mind if my question is bad. I am doing simulations for the first time and am trying to figure out how things work. thank you. |
July 2, 2021, 04:10 |
Write Motion history
#5 | |
Missy
displacement, graph |
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores | puneet336 | OpenFOAM Running, Solving & CFD | 11 | April 7, 2019 00:58 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
How to export time series of variables for one point? | mary mor | OpenFOAM Post-Processing | 8 | July 19, 2017 10:54 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
