May 7, 2016, 01:54 |
Sliding mesh model for outboard Propeller
Stacy
Hi All,
I am creating a sliding mesh for an outboard propeller in order to understand how the downstream velocity profile works. I have done quite a bit of research into tutorials and past work in order to understand how this model works, but it just seems to not be working and the liquid is flowing past/around the rotating volume. Boundary Conditions in use are as follows: Tank outlet = outflow is 1 Fluid= water Model: K-epsilon realisation model with standard wall functions Velocity at tank inlet is 0.04m/s (z-axis), Hydraulic Diameter= 0.217m^2, Intensity=5% Rotating domain: rotation in z-axis =3000rpm Solution method is coupled with standard pressure Interfaces have also been set around the rotating volume. I have attached pictures. Any help would be greatly appreciated as this is for my thesis. Cheers Stacy |
sliding mesh model |
Polyhedra and sliding mesh? | rockewan | FLUENT | 5 | December 1, 2018 19:07 |
Periodic Boundary Conditions With Sliding Mesh Model | Islam Abdelghafar | FLUENT | 1 | March 21, 2017 12:28 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
