Propeller Fluent Analysis
Old   May 12, 2016, 01:05
Default Propeller Fluent Analysis
SELANGOR, MALAYSIA
zizie is on a distinguished road
Hi everyone,
I'm vry new to ANSYS Fluent.
So basically I would want to run analysis to determine the aerodynamic properties of a 10 x 7 inch propeller blade.
I've some questions:
1) Is it possible to run static propeller analysis?
2) If I would want to make it moving at certain RPM, how do I do it?
3) How do I run the analysis to determine the thrust and power coefficient of the blade?
4) Do I run it with laminar or turbulence? Since my Reynolds number at 75% is 50669 at 3000rpm.
Do enlighten me please.
Thank you in advance
zizie is offline   Reply With Quote
Old   May 16, 2016, 04:44
Pedro
pjsc211 is on a distinguished road
I am interested in the same thing as asking zize with the idea of extending a multirotor aircraft.
I try to up the thread to see if anyone can help .
Thank you very much.
pjsc211 is offline   Reply With Quote
Old   May 16, 2016, 22:44
SELANGOR, MALAYSIA
Did you manage to find the solutions?
Propeller flow simulation in Ansys Fluent a1ananth FLUENT 2 December 4, 2014 15:30
analysis of multiphase and porous media in ansys fluent ahmed_khatibs FLUENT 0 November 4, 2014 12:01
Flow Analysis Around Aircraft with Propeller Effect theengineer Mesh Generation & Pre-Processing 0 August 13, 2013 05:37
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
Turbulent Round Jet Fluent analysis Renan Margonar FLUENT 3 June 20, 2013 09:07
