user-defined memory
Old   May 24, 2005, 11:18
Default user-defined memory
Mark
I am wondering if there is a way to pass a value of a variable from one routine to another. For example, I have a DEFINE_ON_DEMAND function that calculates a value for velocity. I want to pass this velocity to my DEFINE_PROFILE function. C_UDMI is a user-defined memory location for cells. Is there one for just a single value?
Thanks,
Mark
Old   May 24, 2005, 11:33
Default Re: user-defined memory
Alec Eiffel
I dont know of any way other than UDM's to pass variables between macros. I suggest you put a thread loop in your DEFINE_ON_DEMAND macro and fills all cells in the domain with with the same velocity value in a UDM. Then when you access the UDM in DEFINE_PROFILE it doesnt matter which cell is accessed because they all have same value.
Old   May 24, 2005, 11:44
Luca
Use a global variable. Luca
Old   May 24, 2005, 11:54
Mark
For clarity, I am using compiled udfs.
Luca,
I have tried this but cannot seem to get it to work. I am relatively new with C and am trying to figure out where I declare the variables as "extern". Is it in the routine I am working with it? just in the .c file? or in a .h file which I then include?
Also, when using external variables do all of the routines have to be in the same .c file?
Thanks, Mark
Mark
Alec
Thanks for the suggestion, but I would like to reduce the looping if at all possible.
Mark
Old   May 24, 2005, 11:58
Luca
I use a unique file, if you have more than 1 file you should pay attention. I declare a variable outside an EXECUTE_ON_DEMAND or DEFINE_PROFILE funtion. This way I can modifiy its value outside the function. I hope to be clear. Luca
Old   May 24, 2005, 12:40
Mark
Hi Luca,
Do you also declare that variable as "extern" inside the function?
Mark
Old   May 24, 2005, 12:43
pUl|
Luca, is it possible to initialize UDM-0 with specified x and y values?
For instance, lets say we have a pipe and I know the experimental values of velocities at certain points in the radial direction. However, I do not wish to use these values in my CFD simulation. Instead, I wish to use these values later in one of my custom field functions that calculates say the sum of squared errors between the simulated and experimental velocities.
So how can I store user-specified values in a UDM for later postprocessing?
Old   June 8, 2005, 01:17
Mahesh
I think u can use the UDM defined in 'on-demand' UDF to 'profile' udf. For post-processing, u can define another UDM with expt. values or define custom field function.
Old   February 10, 2020, 10:04
Raphael
arkie87 is on a distinguished road
Originally Posted by Mark
;120936
Luca,
Thanks, Mark
Global variables are defined outside of specific fluent macros i.e. where you put "#include udf.h"
something like this:
// Include Necessary Libraries //
#include "udf.h"
// Global Variables
int counter;
// Initialization Function
DEFINE_INIT(initialization,d)
arkie87 is offline   Reply With Quote
Trouble setting user scalar and user memory names tstorm FLUENT 6 November 23, 2022 03:58
How can I allocate user defined memory? MASOUD Fluent UDF and Scheme Programming 1 November 20, 2014 02:12
user defined sourcen term xck1986 CFX 1 July 8, 2010 08:35
user defined turbulence model manuutin STAR-CD 5 October 14, 2009 05:29
Gradient of a User defined Variable Ramadas CFX 2 August 21, 2007 09:19
